vrs combi
Hi all. Its about time I started a thread.
first this is a list of a few things I've done:
18 inch bbs ch
polybush -10mm topmounts
new oem strut caps, now fitted with -10mm caps
polished oem stut tops
all new oem bolts/nuts
bilstein b4 "sport" dampers. b4s are 15 % stiffer than stock, b4 sport is 15 % stiffer than normal b4s
pi progessive springs for leon cupra r
audi s3 new oem dampers
polished and wrinkle painted intake manifold
black grill, now badgeless fk grill (not a fan so a change is imminent)
jetex 8001 filer with reduction 80 - 70mm pipe etc
did have custom cai tubing, now custom heat shield and carbon wrap etc and another new 80mm jetex with samco xtreme pipe
forge relocation kit, tried various things to make it look better, even used samco classic matt black pipe but binned it all
ate super blue brake fluid
just changed from crn discs and black diamond race preditor front to nitrac disc and brembo sport hp pads
rear using nitrac disc, just removed mintex 1155 pads for normal black diamond preditors (non race).
goodridge brake hoses for golf 4motion
eibach rear camber shims -1degree
jetex non res system (twin pipe) cut tail pipe so it fits vrs
all new exhaust mounts oem.
wrinkle painted fuel rail
newsouth intake manifold gasket
various polished oem nuts
did atempt to get a company to polish my rocker but it turned out ****, now its wrinkle painted
yoko spec 2 front tyres, conti sport 3 rear
miltek sport dp cat with heat wrap
new master cylinder
vw sharan rear caliper springs, my calipers wouldnt release once the handbrake was off. couple quid and all fixed!
cheapo new front wishbones, fitted with new febi ball joints and superpro bushes and caster adjustment
TYROLSPORT SMIC, bought a new map large sensor as mine is the new small type
ecs coil hold down pack
agu 1.8t charge pipe
new oil pickup
audi tt strut brace, polished , wrinkle painted and brackets removed.
starting to replace manifold hoses with oem etc
mk5 golf coil cover
sorry to bore you, now onto pics:
new oem vs poly
Edited by john_20v
i hated the relocation kit. I tried a few things but it just looked wrong
spot the mistake. Not meant for the vrs!
plus the hanger was all wrong.
Pro speed in cardiff fixed it all for me
**** job of polishing. Lucky i didnt pay much for it!
love bosch parts lol
this spring saves alot of expense
this was crap, now replaced with oem
my transporter was out of action so the car came to the rescue
I won't bore you with anymore for now :)
I need to get some proper pics of the outside of the car.
Edited by john_20v
doh, just realised I've put this in the wrong section!
Can mods move it for me?
ta
Nice looking car mate
I just want informations for your air filter heat shield
:thumbup:
Good job there mate....Love your car!!!!
Sent from my GT-I9001 using tapatalk 2
Nice work!
Thank you for the infos :thumbup:
cheers all
the car is basically all ready for stage two.
I've bought a sfs oversize tip but not fitted it yet. Also need to change my knock sensors again, as I put cheapo eurocar parts ones, and im still getting some cf readings.
I also did this : http://www.terraclean.co.uk/index.html
Either its a wast of time or my engine was fine anyway. I didn't notice a b!oody thing.
Edited by john_20v
Great progress and a lovely looking car :)
Looks great, keep it up :)
Looks great good for ideas as you've done quite a lot. Can I ask were you got your shorter top mounts from?
venom motorsport, but loads of people now stock them. PSI tuning, awesome and on ebay I think
thanks
