Octavia vrs rear disc fit fabia?
Sorry to be a pain!
I'm just about to order a full set of discs for my fabia mk1 vrs 2004 model that are made for the octavia vrs 1.8 as I am doing the 312mm upgrade!
Just wanted to make sure that the rear discs for the octavia vrs are going to be a direct fit on my fabia rears?
Many thanks for the help :)
You'll need the rear calipers and carriers from an Octavia vRS as well.
Rear discs on the vRS are larger and vented.
Thanks for the fast replys! I'v just ordered the sepearte.
312mm octavia vrs drilled and grooved discs
Stock size rear fabia vrs drilled and grooved discs
It's going to shark performance this Thursdays to have witec coilovers, miltek full system and 312mm brake upgrade fitted. I just hope the brakes all fit correctly!
You know can't just bolt the larger discs and pads on right?
you need the calipers and carriers from the 312s as well
