Fitted coil pack cable guide and further messing about
Ok Thanks to Rob and his great website few things I wanted to do for a while
One is fit a coil pack cable guide from a later VW.
This is a simple job and looks great
Part Number is 06F 971 824 C
And at around £8 a great price.
As I painted my Cam cover Black wrinkle  the old Audi TT heat was looking out of place.
Before I started
The part i am fitting is in 2 halves and clips together over the coil pack loom
I cut off the little lugs that hold the guide down as not needed and in the wrong place
Original loom in place needs to be lifted off the cam cover and the plastic cable runner removed. Also undo the earth bolt to cam cover
this is when i noticed one of my coil pack wires had exposed wires.
This is common due to the heat of engine making insulation brittle. I repaired  no.1 coil few years back.
I took the coil pack wiring to the gearbox side and then fitted the new cable guide over it. This is a little tricky as you have to reform the wires into the new guide, not impossible just bare with it.
finished job
I also finished the day with trimming down my engine plastic front cover as removed it due to removing the brackets that hold in down. So decided to trim it ti be able to sit on the remaining brackets and cover the front a bit better
Trimmed a few time s to get it right
Fitted
what's next...........
you are such a bay whore Bowders! :P
wish I had more time as this is what mine looks like :D
Posted Image
Lol.
Drop your car off dude I love a challenge. ...
Sent from my Samsung S3
