F****** Garages
I had my new wheels and lowering springs fitted yesturday and I have just found that the garage has splitt my CV joint I am tamping.
I am going to call them on Monday and make them fix this.
Any ideas how long it takes, and any complications.
Antony
CV joint? What's that?
Its a *** to do! they will have to take the driveshaft off to remove the cvjoint to get a new boot put on it.
@mil the flexable knuckle joint on your driveshaft
@garages to$$ers
Looks like a special tools for the hub nut too.
Make sure they don't try to fob you off with a wrap around one.
The hub nut is a 36mm twelve sided socket. The nut is also one time use only and should be done upto 50nm + 90 degrees.
:thumbup: Time for me to order another couple of bits. :o
edit: Just checking it is this part isn't it? No unique hub nuts or anything I need to worry about?! :rofl:;)
