*Feeler* Thinking of selling my Mk1 octy VRS
I think i must be nuts but am thinking of selling my Mk1 octy VRS
I bought it 3 years ago from a women who had had it since new with 63k on clock,
I've spent a small fortune on it since i got it with full R32 front end and 25mm eibach rear bar to match, also has Jom plus coilovers, (the 400 quid ones they no longer produce not the cheaper versions)
It had G60/VR6 clutch and flywheel conversion using genuine flywheel and sash clutch, i changed oil in box a while ago and have some more to do it again,
I did cambelt and water pump when i bought it and car has now 104 on clock so might do it again before it goes, its had all breather pipes replaced when i did bam manifold conversion and fitted front mount, when i did that i also had front panel sand blasted and painted as it was looking abit grubby,
Front pads are nearly new as are the rears, also had a caliper on back and spring mod to stop noise when reversing,
It has a 2.5in turbo back exhaust with sports cat and stronger front bush on rear box to stop it sagging due to extra weight of system, also has a jabba induction kit with a 3in cold air feed from front of car
It has 2 sets of wheels, my white pro race 3 17's and the standard spiders that have winter tyres on the front, 2 tyres on the pro race wheels are about shot but others are like new, the spiders are around 5mm all round
Inside it has black carpet and full black roof lining conversion, it 2 sets of 4 gauge amp cables running to rear along with 3 sets of RCA cables and a length of 7 core for amp switch live etc, i have some trims to refit inside from doing this hence the reason its only a feeler at moment,
It also has a westfelia detachable towbar and 7 pin electrics, carn't even tell its there when its removed,
http://www.briskoda.net/forums/topic/248336-volvomegs-vrs/ <---- my build thread
I have done a couple of trackdays in it but i change oil and filter every 5k so its been well looked after, had it on rollers at shark other month and it made 220bhp and ready to go stage 2 if new owner wanted, but i never bothered as it was fast enough for me
Sure there is plenty that i've missed and there is a couple of bits of bodywork i want to get sorted before i sell it as am abit fussy so no price as yet
Nice car. Is it an r-tech mapped car?
No shark, got an sts box aswell with original and immobilizer map on it
If you want to sell the pro races back lol there fit my bora, :)
