Vibration with Cupra Intake & Green Filter
Since fitting the intake and filter, I've noticed a vibration from the passenger side of the dash between 1500 and 2000 rpm in all gears. It clears after 2000 rpm though..??
Anyone experienced the same ?
Try putting the standard set up back on and see if it still vibrates
Since fitting the intake and filter' date=' I've noticed a vibration from the passenger side of the dash between 1500 and 2000 rpm in all gears. It clears after 2000 rpm though..??
Anyone experienced the same ?[/quote']
Yep I have, need to sort it, just not had the time :(
The bulkhead end of the air filter box is only held in place by a rubber mounting pushed onto a metal peg. It's not come loose, has it?
I'll check that out...thanks
