Fabia VRS handbrake in regular Fabia?
Is it possible? I don't have disc brakes so does it make difference?
I have regular hanbrake, plastic cover and black button, i would like to install one from vrs, i really like combination of chrome button and leather cover.
Edited by djordjebg
The leaver is usually a straight swap.
Keep in mind they have two different handbrake mechanisms
Well i just want to change handbrake lever as it looks way better.
I found it in ETKA and they have different last letter of catalogue number ( disc model and drum model).
You think that i won't have problems because of that?
I'll go into more detail.
The covers just pull off, meaning you can remove your cover and slide the vrs cover on, but...
You won't know which type of mechanism you have or which one the vrs is until you try and fit it.
The one on my sdi was different to one I removed from a silverline edition, so I had to change the full leaver mechanism and the cover. It's easy enough to do but if the covers were swappable between mechanisms it would have been a lot easier.
