Bilstein B12's fitted
I changed top mounts when suspension was changed. Garage advised they were looking a bit past their best.
That was at about 70k.
  • Replies 50
  • Views 7.9k
  • On the DPM Performance website, it states the B12 kit gives a 30mm drop. The Vrs sits around 20mm lower than the standard octavia, so you can only expect a 10mm drop. But it'll take a few miles/weeks
  • We'll go way off-topic with this one, and will only drag the discussion off in a different direction.    With modifications, the expectation always is from the insurers side that you have fitted par
  • If you've got the wrong springs, for a lighter vehicle, then it's going to dive more heavily under breaking and acceleration. The springs could fail due to the extra load.   For the cost of fitting
