Octy vRS 1U fault codes and some other problems
Hello guys!
I hope you can help me in any ways :)
Tuesday,29,October,2013,19:19:10:46862
VCDS Version: Release 10.6.0
Data version: 20100630
Chassis Type: 1U - Skoda Octavia I
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 56 76
VIN: TMBER41U018453073
Address 01: Engine Labels: 06A-906-032-AJQ.lbl
Part No: 06A 906 032 BJ
Component: 1.8L R4/5VT 0002
Coding: 11500
Shop #: WSC 07158
VCID: 67D6B9C26937C224
TMBER41U018453073 SKZ7Z0A0833063
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 1C0-907-37x-ASR.lbl
Part No: 1C0 907 379 D
Component: ASR FRONT MK60 0103
Coding: 0021505
Shop #: WSC 31480 000 00000
VCID: 2B5E05F2B55F2644
Address 08: Auto HVAC Labels: 1Ux-907-044.lbl
Part No: 1U1 907 044 A
Component: CLIMATRONIC C 1.0.0
Coding: 01000
Shop #: WSC 31480
VCID: 3064129E9C79459C
1 Fault Found
01274 - Air Flow Flap Positioning Motor (V71)
37-00 - Faulty
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 601
Component: 0F AIRBAG VW5 0006
Coding: 12358
Shop #: WSC 31480
VCID: F0E4529EDCF9859C
Address 17: Instruments Labels: 1U0-920-xxx-17.lbl
Part No: 1U0 920 810 C
Component: KOMBI+WEGFAHRSP VDO V05
Coding: 07112
Shop #: WSC 06435
VCID: 2D5A0BEA8B4B2874
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 31480
Address 29: Left Light Labels: None
Part No: 1U0 941 651
Component: EVG GDL + AutoLWR 0002
Coding: 00006
Shop #: WSC 31480
2 Faults Found
01539 - Headlights Not Adjusted
35-00 - -
00496 - Sensor for Vehicle Leveling; Front
07-00 - Signal too Low
Address 39: Right Light Labels: None
Coding: 00017
Shop #: WSC 00000
1 Fault Found
01042 - Control Module; Not Coded
55-00 - Adaptation Not Successful
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No: 1J0 959 799 AH
Component: 5H Zentral-SG Komf. 0001
Coding: 04097
Shop #: WSC 31480
VCID: 840C0E4EF841893C
Part No: 1U4959801B
Component: 5H Tõrsteuerger. FS0002r
Part No: 1U4959802B
Component: 5H Tõrsteuerger. BF0002r
Part No: 1U0959811B
Component: 5H Tõrsteuerger. HL0002r
Part No: 1U0959812B
Component: 5H Tõrsteuerger. HR0002r
1 Fault Found
00849 - S-contact at Ignition/Starter Switch (D)
25-00 - Unknown Switch Condition
End ---------------------------------------------------------------------
This is my LOG file. Can someone please explain these fault codes. I'm especially interested in the last one "Unknow Switch Condition". What does it mean and how can I fix this?
And I have another problem... When I put the pedal to the floor the car starts accelerating but all of a sudden looses power (like the turbo would stop working but I can hear the dump valve) and then goes on normally and looses again and so on. This doesn't happen always. Any ideas what it could be wrong?
ps: Sorry for my bad english
Have you any turbo-timer?
If you have this maybe cause the last problem with ignition switch
What is a turbo timer? Oh and by the way I replaced the original dump valve with forge blow off valve if that helps anything...
Clear the codes & see what comes back.
Flap fault is common & usually caused by a siezed heater recirculation flap motor. Google will reveal the fix.
VAG 1.8t's require a recirc valve & will not run correctly with a BOV. That will be the  source of your boost problem.
Ignition switch is probably worn.
I have solved the problem with power loss today. It was fuel pump. It had to be replaced.
