Vrs Sidelight earth
Hi All
Can anyone tell me where the earth is located for the N/side sidelight on an 06 Fabia VRS. I have replaced the bulb and it just glows.
Any other suggestions beside earth appreciated.
the earth comes in with the loom for the light unit in the block connector that plugs into the headlamp
Hi
Thanks for the reply.  What I need to know is where the loom is earthed so I can clean up the earth point as I think this is the problem.
Hi All
Are  your headlights ok ? if so its not the earth ! have you put a 24 volt lamp in ?
Radiotwo
