Pollen filter?
Windows r misting you like mad and as car has all new door seals in guessing it's the pollen filter
Just wondering where they are and how easy they are to fit
Under the dash on passenger side footwell iirc look for a flat cover clip kinda thing, they only cost a few quid
£9.84 at ecp but chill25 promo code requires £10 spend, need some screen wash ?
As said above, it's under the passenger footwell/glovebox.
This old thread give a better idea, and tips for changing them.
Where-is-your-interior-fabia-air-filter/
i paid £5.50 at local spares shop, never seen so many leaves and muck fall out
Got one from Andrew pages £5.91
it should get better as the interior dries out, i had problems with water inside the car making lots of condensation with my NX, new seals and a good going over with a wet vac and it was much better, if you're still having issues put a couple of the desiccant dehumidifier boxes in the back footwells, pick them up from the pound shop usually, helps trap some of the moisture in the car
Pete
