noisey vrs
hi all as ya all know i fitted prosport coilovers last week all good so far well i thought so we let the front end settle and i decided to lower it a bit more now when driving im getting a metalic noise from driver side front wheel sounds like the back plate rubbing against disk any ideas i think i may need to raise front end a bit
I had a similar noise, issue was the pancake pipe rubber washer had torn where it mounts to the body and was rattling, might be that.  Mines not lowered tho'
Edited by Liverpool-Lad
could be a number of things buddy best get under car and take a few pics with car on road surface as if you jack up car will miss what is probably rubbing.
could be drop links,
could be wheel rubbing coilover platform
could be ARB drop link hitting pancake pipe etc etc
going on a 4 poster ramp tomoz cant be droplinks as they are the ones i was told to use defo not wheel rubbing mate might need to raise front end a lil bit
How much have you lowered it.
My car is super low and no rubbing
hope you get it sorted..
UPDATE - All fixed took off the front wheel and had a look ended up being a loose ABS ring
