Will this fit my Octy Mk1 VRS?
Yeah they should, it says they are for AUQ engine code on the original ad, which is the Mk1 Vrs
They look about right...don't know what the straight pipe at the bottom is for though?
All other auq boost hose kits are 5pc to my knowledge!
Yep will fit although you won't be using the 2 pipes on the right. The 90' bend and the short fat pipe as these are not needed or used on the AUQ VRS engine. The long small straight pipe is probably a generic pipe to replace N75 or DV hose. The big pipe is the intercooler to inlet manifold pipe. The pipe on the left is rear turbo pipe to dv. Comes off the horizontal metal pipe at back of engine. The smaller pipe to the right of it is small rear turbo hose to N75 valve.
Sent from my Samsung S3
