Serial adaptor for VAG com?
Is there one?
It turns out this laptop I was hoping had a nine-pin (two rows of 4 & 5) port on it, but think I need some form of adaptor to connect this to the really long serial port on the back of the laptop (which I guess is the old fashioned way of connecting a printer)
is this part fairly common and cheap?
Just reread your update and think I know what you mean now. You need a 9-pin to 25-pin serial adapter :D Yep available from places like Maplins, IIRC.... just make sure you get the right gender!
Chris
No - It just has a small connector on it, with 4 rows of holes on top and 5 on the bottom (or vice versa) - I need to get that into a connector on the laptop - I suspect using some form of adaptor. :)
J, you can get a USB converter - plug your serrial cable in to it, it then plugs in to a USB port on your PC :D
If you have a 25pin DIN on the back of the laptop that's more likely to be a parallel printer port - this won't work with VAGCOM AFAIK.
Can you tell us what model of laptop it is, or supply a pic of the ports on the back? Typically they have little logos next to them to describe their function - the printer one is like two rectangles normally:
[___]
You would need a 'Gender Changer' DB9 to DB25 BUT one is serial and one is parallell and I'm not sure if parallell will run VAG com.
I have got a USB to serial but I've not tested it yet - I'll post it to ya if you want to borrow it.
Many people have had problems trying to run serial cables via converters from USB ports - just a heads-up
Yeah I've heard that Nick. From what I can gather it may be down to cheap convertors. I must get round to testing mine, but I have an old Dell that has a serial port and I'm keeping that for now.
Jason, if you get stuck, I'll lend you a laptop with VAG COM on it, with correct connectors :D
I'm off into Exeter armed with the cable to see if I can find the right adaptor. PC World gets my first visit. :cool::D
Jason PLEASE LOOK AT THE LAPTOP FIRST - it won't be any good getting an adapter and trying to plug a serial cable into a parallel port! :eek:
Jason, you have my mobile no, if you want a loan of a laptop, gimme a bell, it'll only take an hour to exeter for me.
I'm away for the weekend but am happy to pop down this arbo :D
PC World in Exeter have the adaptor; I've bought one there before. Take you bits along to make sure you get the right one.
I bought the cheapest USB to serial adaptor I could find on ebay - works perfectly. Just pot luck though I guess.
