Who to contact
I have done several scans now with VCDS and have noticed the same issues pop up.
Is it worth contacting Skoda UK to find out exactly what my chassis number should have fitted (including any extras) as it's doing my head in not knowing why some issues are constantly reoccurring as its not recognising something that may be fitted but not working or vice-versa
Steve
don't bother
if you tell skoda uk that you have faults show up on a scan, they will want it to be plugged into a dealer machine and charge you
a better solution is to post up what issues you have
The options sticker in the boot should give a fairly good list of what is fitted. There is a website that decode the options, don't have a link to hand.
Cheers fellas,
Eddie- The issues are generally no comms with 37-Nav and 56-Radio but both work fine. The radio one often throws up "problems" surrounding digital sound package which is why I don't understand what's up as I don't know if it was ever meant to have it! The unit fitted is Columbus so again don't know if it's retro or not :-(
It sometimes says special operations no comms which I have posted about before and I'm still trying to find out it's history from new.
Another new one is intermittent wiper control malfunction- it has auto wipers so not a major issue.
Trundlenut- cheers for that if you find out what it's called please give me a shout
Thanks again guys
Edited by steveo82
I'm guessing that the nav has been retrofitted, probably from a car with the soundsystem (so that fault is down to coding)
So the communication error is either due to the wiring or the Columbus.
If the columbus is at fault, do you know the firmware, some modified firmwares can cause the communication issue
Eddie- here's my standard kit direct from the sticker in the boot
E0A = No special edition
1D0 = Without trailer hitch
6UB = Left exterior mirror: electrically adjustable, convex
6TC = Right exterior mirror: electrically adjustable, aspherical
1KP = Disc brakes, rear
6FB = Body-colored exterior mirror housings
1AT = Electronic stabilization program (ESP)
3FA = Without roof insert (standard roof)
1N3 = Speed-related variable steering assist (Servotronic)
1NL = Covers for alloy wheels
H7D = Tires 225/40 R18 92Y xl
4UF = Drivers and front passenger air bag with front passenger air bag deactivation
4R4 = Power windows with comfort operation andcircuit breaker
B09 = Type approval Great Britain and NorthernIreland
3QT = 3-point seat belts with tensioner and height adjustment, front
4X1 = Side air bag front
4A3 = Seat heater for front seats separately controlled
8L5 = Roof antenna and "diversity" window antenna
J0L = Battery 340 A (70 Ah)
7AH = Electronic vehicle immobilization devicewith alarm system, passenger compartmentcontrol and backup horn
8GU = Alternator 140 A
6Y0 = Without cruise control warning system
9AK = Climatronic with impact pressure control free of cfc
8RM = 8 speakers (passive)
7Q2 = Navigation system with color screen
8AY = Radio/navigation system
8QL = Key for locking system with remote control
8X1 = Headlight washer system
4K3 = Radio remote controlled central locking operated from inside and safe securing
G07 = Front shock absorption
QN1 = Drawer under left front seat
3L3 = Manual height adjustment for front seats
9P1 = Seat belt reminder, electric contact in buckle
7X1 = Park distance control
9W0 = W/o car phone preparation/installation
8WR = Front fog lights
7A2 = CD changer
3GA = Without cargo area
QG1 = Service interval prolongation
7GG = Emission standard EU4 DPF
L58 = Suspension range 58 installation control only, no requirement forecast
7P4 = Manually adjustable lumbar support in front seats
F0A = No special purpose vehicle, standard equipment
3S4 = Preparation for roof load rack
2UC = Sports version
Looks pretty bob-on to me and as you can see it shows colour nav as fitted by factory but 8 speakers(passive)?? is this normal in the vRS? And G07- front shock absorption, what does that mean I get front shockers!!??
6YO- W/O cruise warning-what's this??
Any thoughts appreciated mate
Steve
Edited by steveo82
doesn't mean the columbus was factory fitted
your car could have had a Nexus Sat nav and that was upgraded
Yeah fair point, however works fine with the maxidot when running with the nav it show shows compass direction, road number and has turn off countdown etc etc working ok.
Other thing I've had trouble with which I cant find a module or fault codes for is Cruise control, I just can't get it to work, are there any tests with VCDS that can be done to find the problem??
