What else to do
Ive hit a brick wall now. I keep gettin limp mode. Been tild to do the mr muscle trick so i did it and it lasted a week and then my car decided to go into limp mode again. I havnt got any boost leaks and the actuater moves freely. Anyone got any ideas?
Sent from my GT-I9505 using Tapatalk
Plugged the car in to vcds?
Yeah and it flags a fault 17965
I'm sure you've already checked Ross Tech wiki:
Possible Symptoms
Reduced power output
Limp mode
Possible Causes
Boost Pressure too High
Hoses/Pipes incorrect connected, disconnected, blocked or leaking
Charger Pressure Control defective
VNT (variable nozzle turbo): nozzles stuck
Solenoid Valve for Boost Pressure Control (N75) defective
Possible Solutions
Check Hoses/Pipes to/between Components
Check Solenoid Valve for Boost Pressure Control (N75)
Check / Clean / Replace Charge Pressure Control
Check / Clean mechanism for variable nozzles
