Confusion over front brake pads
I have an Octavia 4 x 4 1.9 Tdi first registered 14/06/2006 and need to change the front brake pads. I have been supplied (by a French company – I live in France) with a set of Ferodo FDB 1398 pads. These look similar to mine except they have a large claw type clip riveted to the back face of all 4 (on the outer pad mine are just flat – not checked the inner). One pad also has wiring for a warning light (I don’t know whether my car has that facility. Any idea what the oem part number is ?
The inner pad has the clip on it to secure it into the caliper piston. If you car does not have sensors these can just be cut off before fitting.
Ok, I can see how the clip locates in the inner piston. The outer pad that I currently have fitted has no clip (understandable because there is no outboard piston). I can't search for parts in France with the UK car description as they use different descriptions here so I really need a part number for the brake pads themselves .....
Anyone ?
For future reference, yes, my car does have the sensors in the front pads
The brakes were just replaced all round before I bought my 06 L&K and they too have the large clips on the pads which I've never seen before.
Clips on the inners to attach to the pistons and the outers simply grip the caliper fingers.
The rears only have clips on the inner piston side.
