Light Sensor and temperature
Does the auto light sensor turn on the lights if the outside temperature goes low than 8º degrees?
I think my lights is turning on if the temperatures is lower thant 8 or 8,5º
I believe they come on when it's raining but I don't believe there is a link to external temperature.
I believe that they come on in certain bright sunlight situations as well - making it easier to see you in bright sunlight - like you can get in the Winter where the sun is low.
A forum search may help.
most definitely it doesn't.
it gets below 0 degrees here and the lights don't get switched on.
the light sensor is purely based on light sensitivity.  no input from the temperature.
Ok thank you :)
