downpipe removal
How the hell does it come past s rack etc help desperate
Should come out easy enough. Is it on a jack your doing it? U mite have to jack it up higher so u can pull it down.
+1
Need to get car high enough to be able to undo the 4 bolts and then pull out and twist past the steering rack. Done a few and very straight forward.
The Downpipe needs to be clear enough from the ground to do this
Think you may be right about height I wondered that already. have been told that I need to losen rear of sub frame on the 4x4 too
