H&R spacer - DPM
Does anyone know what thickness spacers H&R start having a locating ring on for the wheel
Is it the 16mm ( 8mm each side ) or is it 20mm ( 10mm each side )
Hmmmm
Hmmmm
I think hub centric starts at 10mm each side as there is not enough metal to add the centre spigot on any smaller.
Sent from my Samsung S3
H&R do do an 8mm hubcentric
Comes with longer bolts
Ah 8mm would be awesome
Now i just need Damian to pop up
From Dpm
He list 2 8mm options
Or psi do them minus bolts as i will use black ones :)
Cheers snow. Yeah there are 2 versions of the h&r 8mm spacers
Just need to confirm what sites sell the rite ones
Found on larkspeed but sooner give the business to damian as a brisk sponsor :)
Yep, there's a flat-external faced single-sided hubcentric version
Worth noting the double-sided version has that spiggot tapered neck design, which means it doesn't fit some aftermarket wheels
They fit my genuine R32's and Spiders, but don't fit my R32 reps or some dezent alloys I had
I think the 3sdm spigot is tapered iirc
Will nose when i get chance
Either that or its **** or bust i suppose lol
good to know
I may have to get some of these :thumbup:
