DPF Replacement? VCDS data
Hi Guys,
I wonder if I can wade in here and ask for some help. Following the advice and guidance already posted in a thread, I believe that after carrying out a diag and forced regen the information obtained is telling me the following
I used both the Measuring blocks and Advanced Measuring Values on the Engines module controller to obtain data.
A member in this forum has experienced his DPF indicator intermittently showing on the instruments cluster,
After reading LOC 068 these were obtained:
5.5%                                      87.17                                   0.00%
Carbon Load Coefficient       Carbon Mass                       Carbon Mass Learned Value
LOC 075
171.5'C                                 301.4'C                              5.5%                                580.8'C
Temp Before                         Temp Before                     Carbon Load                    Temp After Particulate Filter
Turbo Charger                      Particulate Filter                 Coefficient
I forgot to save the data for LOC 070 but from what I do have am I right to think the Carbon Mass is at 87g? suggesting the DPF is gubbed?
