Octavia II, BKD engine, 3 loud beeps when switched on from cold only!
Morning.
Just recently, and only very occasionally when switched-on for the first time after a few days, there 3 loud beeps from the dashboard area before the warning lights go out - and they do all go out and stay out! - and then the car runs fine and does not repeat the signal when switched-off and re-started (either immediately after the beeps or later in the day)!
Has anyone any ideas as to what these are about?
NB: the only thing I have noticed is that, when checked on the cold engine, the oil (505.1 spec, IIRC) level is getting down towards the Minimum mark on the dipstick - and I intend to top it later today - because of some recent longish journeys.
Thanks in advance.
John
Edited by jeallen01
A guess, low battery warning. But my BKD Octavia has never done it despite a dodgy battery earlier.
Thanks and worth a thought, although if it is that then there don't seem to be any other signs of a weak battery because the car starts OK and the lights seem normal intensity. :think:
OTOH, the car is 6yrs/95k miles old and the battery is probably the original (am the 3rd owner, so can't be sure).
John
Edited by jeallen01
Mine was fine most of the time, but did suffer seriously if I left the radio or blowers on for too long with the engine not running.
Thanks, I'll try to make sure I don't do that (but don't think I really have done so very much anyway)
Regards
OTOH, reading the US TDI Club forum, it might be something like the "Comfort Control Module" - see this link http://forums.tdiclub.com/showthread.php?t=342756&highlight=tdi+beep. Although it refers to earlier versions, the same thing might make sense in my case :wonder:
John
Edited by jeallen01
