SPACER FAIL - ooops
Ok guys so no one else goofs :D
Damian from DPM sorted me a cool deal on some yummy H&R 8 spacers with the locatiing ring
But :D
Yeah the dont fit :(
I popped the spigot ting on and due to the shape of the locating ring it dodnt do back flush to the spacet :(
Cheers to Damian tho for sorting the fast tho
And sorting my 5mm version :)
But yes
H&R 8mm per side spacer dont fit 3sdm spigot
852D62B3-F4A9-494A-8AD8-12F955554D7A_zps
Doh :D
Told you they were fussy ;)
ps
Its the wheel thats' failed - they should have copy OEM spiggot dimensions, H&R have
It almost goes on it starts slotting in but the face of the rim sits about 4mm away from the spacer
The spigots are sortve shaped
But not quite lol
Found exactly the same when switching from my genuine R32 wheels to my R32 reps
Luckily the R32 reps were a larger offset, so just cleared my brakes without spacers
Why does the spacer have the shape?  I would have expected the shape to be straight down to the face of the spacer?
Weird aye lol
Im guessing its to do with thickness
My 20mm pcd adaptors were pretty straight
Odd
Dpm have been awesome tho, i can pop them back being i only put a spigot ring on lol
Strength, imho
When creations motorsport copied 'where inspired by' the H&R, they machined out a little too much metal, and the neck can snap off
CreationsMotorsport_8mm_Broken_Spacer_00
And if you look on the back of the wheel this is also chamfered.
creation Motorsport spacers are sh**
As above they are crap
It is to do with thickness. There is just not enough metal on 5 to 8mm spacers to have equal length spigot rings. Creation motorsport are a classic example to try it and fail as they are equal length spigots but crack due to not enough metal.
Sent from my Samsung S3
My creations spacers centre bore was way too tight on the hub too
Wouldn't sit on flush. Well not without the aid of a hammer
You'll probably find they've come apart now then or a crack the whole way round
They were actually 12mm ones. It seemed the centre bore was too tight
They actually survived and didnt crack. But i certainly wouldn't buy them again
I wonder what size h&r would become equal straight sides
10mm iirc
I think i'll stay 5s lol et25 rims may cause issues ha ha
10mm iirc
yep....
Mine are 12mm and straight
Et23 lol my rims will soon be out the arch snd on the way down the street :D
