Lambda sensor change
Hi, my EML came on over the weekend, I plugged it in today and it came up with fault code p0135 and p0030.
I've read posts on here and else where that it's sensor 1 lambert sensor ( the one before the cat).
These do not seem to expensive to buy but is it a d.i.y job to replace one, cheers for any help Phil.
Lambder not lambert bloody iPad predictive text.
Lambda sensor even... :rofl:
Will move this to Octavia 1 section
Should get more views/replies there
yes is quite easy to replace 2 spanners needed ..... 22mm for the sensor itself and a 10mm for the plug housing under the car.
Give it some penetrating oil and let it seat for a couple of minutes,they are pretty tight and tend to "weld" to exhaust due to high temp.
