Revision D dump valve
Could anyone tell me when the Revision D was fitted as standard? I have an early 2008 car and was thinking of going rev D but Im not sure what is currently fitted?
Dan
The latest DV is Rev G
Would this be the correct part number for the REV G diverter valve -> 06F 145 710G
As far as I can remember that looks to be the correct number
Cheers. They are pretty cheap too. (helps that I work in a Seat dealers selling parts!)
Why are you replacing your DV? I had thoughts to replacing mine (I kept getting an emissions light and DV, PCV and a charcoal canister was suggested to be changed to cure it)
How much can you get a DV for and could you hook a fellow Briskodian up? ;)
Skoda sell them for about £40 iirc. It's advisable to change as the original versions do split.
If your car is mapped it's one of the first things you should replace, as it is very likely to fail when the turbo runs more boost.
I have run the G on my TFSI Golf for 10k miles with SHARK Stg 3 (stg 2+) with absolutely no issues.
The reason for me wanting to change mine is purely for the fact that I'm still on my original and I know that they have a tendency to leak. So for 30 quid it would seem to be worth replacing.
Double post. Oops.
Edited by octydan
by the time I put postage on from the isle of Wight it would probably work out cheaper getting it from skoda tbh.
  • 9 months later...
How do you know what version you have without looking as i don't know how to look and not wanting to start taking that car apart?
