Skoda octavia 2010 fl drl problem
When i activate the drls using vag .. It show on the driver screen check lights , but the lights are there and intact and not burned .. Wts theproblem ???
Are they the correct type of bulb (i.e. not LED as this will cause a bulb out warning)
Yes theyre the original ones
But even thou they dont light up
Is the wiring complete inc the earths to both lights?
Which DRL's are you referring to (ie fog light or SMD/LED type). Have you checked the bulbs and fuses ?
