16490 -manifold\barometric pressure sensor (G71)(f96) p0106-35-00 implausible signal
You need to set the engine at TDC on cylinder number 1 before checking the timing.
haw cane i  set engine at TDC ?
and whay u say set engine at Tdc Before Checking The Timing ?
and cane u give me timig place fabia 1200 3 clinder
Edited by MohamedKaram
You can check TDC by removing number 1 spark plug and using a long screwdriver to check when the piston is at the top and see that the slots in the cams are in line.
If there is a timing problem then you will have to take the car to a specialist because you will not be able to repair it yourself.
i do that  asrewdrive 2 piston at the top and one piston in the deep
i  chevked 3 piston - 2 in top one is done in the deep
the write 3 pistone in top or wate?????????
i  chevked 3 piston - 2 in top  1 is done in the deep
see this pic
Putting it simply.
Take out Spark Plug number 1, next to the Timing Belt, put the screwdriver in spark plug Number 1 hole, turn the engine slowly by hand until the Piston is EXACTLY at the TOP of the stroke, indicated by the feel of the screwdriver.
Now take your pictures.
DB
Edited by mogwye
Putting it simply.
DB
thank u for healp  after make this chiking timing like pic ?
ISNP
WAT MEAN THIS MSG IN DASH
I CANT ERSE IT
AFTER THIS MY CARE GIVE THIS ERRO
AND I CHANGE MAP BUT NOT FIX AND I CHIKED TIMING IS GOOD
WAT I CANE DO
 FIRING
