Ignition Switch advice
Hi all, I am a proud owner of a 55 plate Octavia Elegance. I was able to successfully use these forums to install a new stereo into the car - Alpine double din. I have also been able to get everything together to sort out the ignition switch issue! (Go me!)
My question relates to wiring into the fuse box - any advice in which number fuse input I should go into, and then what size fuse I should put in on top? Any advice would be extremely gratefully received. For info, I have a 'fuse tap', with wire to create a new circuit (I will take the 8amp wire from this to the stereo), there is then space to put a fuse in on top.
Thank you very much in advance!
When ah say Bo let mi hear ya say Selectaaa!
Ee-hee, sharmone mutha * * * * * *!
Proper Bo!
Anyone? I would really appreciate advice on which fuse to use. Thanks!
Rear wiper, heated rear screen?
Thank you all for your help! I managed to figure this out in the end, VERY happy to have the job completed - simple once you know how :-)
