Help with cupra r subframe conversion please
Got a mk1 Vrs and its already got a "quick rack" on it but im now buying the leon cupra r cast wishbones and hubs tomorrow, is the subframe the same for a straight swap? And do I need to get the arb and droplinks too?
Subframe is same well apart from stiffer bushs and lower brace mountings,
Straight swop
Subframe is same well apart from stiffer bushs and lower brace mountings,Straight swop
cheers bud. So I dont need the arb? Is it the same? As the guy is giving me his arb polybushes too.
I had a R32 but I believe the cupra R one is 21mm where as the VRS one is 19mm and the R32 one 23mm
Ok think ill get that off him too :-) cheers
LCR arb is 18mm, and vRS is 19mm
