Trailer indicator lights not working
Hi All,
When my trailer is connected to the cars electrical connector, with the exception of the trailers indicators, all the lights work (the trailer lights are fine - tested on another vehicle).  Also, the cars rear indicator lights dont work when the trailer is connected (front inds are fine).
As the bolts were very corroded, I managed to brake the cars electrical connector.  Inside the connector was a (microswitch PA66-GA15 on the housing and DC9 on the microswitch).
All the connector wiring seems to be fine, sockets and pins are clean.
Can anyone help? i dont want to replace the OE equipment with a unit from Halfords.
All help is appreciated
Mark
If the car rear indicators fail to work when the trailer is connected then that would suggest to me that there was a fault in the trailer wiring.  I know you said they worked when attached to another car, but maybe both the trailer and other car are wired up incorrectly.
Does the Octy have an additional relay/sounder unit which beeps when the trailer indicators are operational (or should be illuminated)?
Is it a factory fit towbar, or 3rd party?
If you place a voltmeter across the necessary connectors on the towbar socket and operate the indicators do you see +12v for the left and right bulbs?
I am not sure what this microswitch you talk about it?
If the towbar is oe, then the microswitch is probably a rear fog lamp cut off for the vehicle lamps when the trailer is connected.
