Wing mirrors from mk2 ?
Hi. I just wandered is it possible wing mirrors from Oktavia mk2 to fit in mk1? Those with the build in turn signal. May be if mirror bases are the same?
there was a member who did do this to a mk1, can't remember his name.
Yeah it took a lot of work if I recall.
dsmithmobile did it :)
The mounting/mirror bases are different so not a direct swap from what I remember.
I did it as Phil w says but needed to modify base plate and make new mountings and use fibreglass and body filler to smooth it in and then had to splice into the loom for the wiring pick ups.
Here's a couple of pics of them fitted
