My Dyno Results
Result!
I reckon the torque level is spot on too, any more is too much IMO without LSD.
  • Replies 51
  • Views 3.9k
  • Indeed it's a custom map! Hybrid 150 Joe with a billet wheel. Cheers everyone.
  • The 204hp map isn't pushing it's capabilities, that was only tuned slightly from my old map which I had for the standard clutch. It's the big map that counts. As for the torque it's smooth rather tha
  • Billet FTW!  Mine has a billet wheel fitted and i know it can push a lot more boost than I am currently (2.2 bar now, 2.7+ bar expected eventually)
Bet this is awesome!! What exhaust tip did you get?
Twin 3" straight cut tips mate, but different to the normal ones :)
The noise difference though is incredible.
5500rpm? My limiter is still at 5000rpm. Yours must have had a limiter raise - Who did the mapping? :)
Yep, surprising how much more 500 rpm actually is when it's already pulling like mad!
Mapping is done by Dirty Torque :)
Result!
Thanks Joe, like you said too much torque will ruin my tyres! It sure is fun with those figures regardless.
Great figures! That using stock nozzles?
You said you went for a lower map, what's the figures?
Remember skudmissile getting similar figures on stealthy dyno using a washbrook map. But settled for a lower figure.
Edited by faboka vrs
Great figures! That using stock nozzles?You said you went for a lower map, what's the figures?Remember skudmissile getting similar figures on stealthy dyno using a washbrook map. But settled for a lower figure.
Yes mate stock nozzles.
I've had 3 maps,
1 - was for using the standard clutch on the hybrid turbo
2 - slightly adjusted which is the 204bhp map you seen
3 - is the 244 / 245bhp map!
I'm running the 2nd map again now though as yesterday after going out for a run with another member off here I started suffering head lift on boost. So PD150 head bolts are being ordered from TPS and then the 244bhp map will be put on again.
Both maps are on the ecu they just require switching over with vag com :)
How do you know when your getting head lift dan?
Started loosing power and coolant dropping mate.
you lose coolant. :)
I don't seem to suffer with this which is good for me.  Could be because my head is ported so flows better, and less pressure building up to cause head lift.
Guys
What billet wheels are you using please, my pd150 hybrid could do with a new wheel as at mo running on standard vnt20 52mm wheel as fitted to audi v6/ saab
I've been driving it around like a puff.
Probably cause you are one................ :o
Guys
I am running a billet wheel from Darkside in my GTB2566vk turbo.
Where the 150 hybrid billets come from I am not sure.
Guys
Get in touch with Dirty Torque :)
Now then now then, don't make me pull another grandad joke ;)
Will be good to see how this goes around Combe now Dan :)
Ah you're going to Combe Dan! Will be good to meet you bud :)
Bloody hell. Thats a long way to travel aint it ?
only 158 miles.  :)  I've driven 300 home after a trackday before. :D
It's about the same for me heading to Combe
If you are already suffering head lift then the damage is most likely already done
New head gasket time along with pd150 bolts
Indeed I am going to Combe :) going on track aswell but be very nervous for that!
Quite possibly, although I'm not the first member to experience headlift, who's then fitting the bolts. The PD150 head bolts are already in the hands of Dirty Torque (that's why I got them from TPS) and are being fitted this week :)
I've been plenty further haha!
When is the next track day amd any spaces. I wouldn't mind going . Do you need any special licences lol?
Combe is fully booked now mate. No special licenses it's only a bit if fun :)
