VCDS CH function Teesside
Hi,
Can anyone tell me if CH function can be activated on a Octavia MkII without auto lights?
Currently my headlights are set to on all the time which I need turning back to factory setting with VCDS. CH lights would be great if possible??
Tried to find someone with VCDS in the Teesside area but not having much luck at present.
Anyone out there that's able to assist?
Hi, and welcome to Briskoda.
If you have the LH/CH function activated without the light sensor / autolights then they will work all the time, regardless of day or night.
Do you have auto wipers? If so, the upgrade to auto lights is a wire, a switch and some coding, then the LH/CH will work correctly. :)
