06 vrs front fog lights stopped working.
Hi All, i'm after a bit of help.
had a N/S headlamp bulb blow, warning light came on the dash etc. it was the middle of the night, cold dark and wet so thought i'll put the front fogs on to help see a bit better but they weren't working! pull the switch out 1 click and nothing, no light on the dash or anything, rear is fine the dash light comes on as it should. i replaced the headlamp bulb and that now works fine with the warning light now off on the dash but still i have no front fogs.
any ideas?
fuse?
even if seems ok, Exchange the guilty one. It may be a cheap solution to simple problem
checked fuses and all are fine, went through every fuse in the car while i had my meter out.
I don't want to sound as though I'm taking the mick - I'm not!
Have you physically checked them to see if they are working?
The reason I ask is that unlike the rear foglights the light on the dash that tells you that they are turned on (green) is on the actual light switch itself for the front fogs, not as you'd expect - next to the light for the rear fogs on the dash (orange).
Edited by silver1011
yes i have checked. lol. to be honest i couldn't remember if there was a dash illumination for the fronts or not but yes i got out the car and had a look, no fog lights.
