ESP/ASR/TCS light stays on after exactly 10 mins - Scanned
Hi all,
Done a search everywhere and it comes up with faulty sensor as the suggestion however...
This is the sequence of events:
1- Driving normally, TCS light comes on while driving
2- Testing out things, its exactly 10 mins into driving everytime
3- TCS and ABS works fine in that first 10 mins, maybe the ABS is a bit over sensitive but the tracking needs doing so could be that.
4- Decided to get a VAGCOM scan and it came up with the below diagnosis:
Address 01: Engine Labels: 038-906-019-ASZ.lbl
Part No: 038 906 019 NF
Component: 1,9l R4 EDC G000SG 5839
Coding: 00102
Shop #: WSC 13765
VCID: 68D49B26087E875E3C3-4A6A
TMBWU46Y044145444 SKZ7Z0D2530055
2 Faults Found:
17911 - Load Signal from Alternator Term. DF
P1503 - 35-10 - Implausible Signal - Intermittent
18057 - Powertrain Data Bus
P1649 - 35-00 - Missing Message from ABS Controller
Readiness: 0 0 0 0 0
 Address 03: ABS Brakes Labels: 6Q0-907-37x-ASR.lbl
Part No SW: 6Q0 907 379 AB HW: 6Q0 907 379 AB
Component: MABS 8.0 front H03 0001
Revision: 00000000 Serial number: 00000000000000
Coding: 0000008
Shop #: WSC 00424 210 81323
VCID: 7DFADA7227FC32F6FF5-508E
5 Faults Found:
00003 - Control Module
014 - Defective
Freeze Frame:
Fault Status: 01001110
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Mileage: 216701 km
Time Indication: 0
18265 - Load Signal
P1857 - 000 - Error Message from ECU
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 55
Reset counter: 95
Mileage: 218264 km
Time Indication: 0
01314 - Engine Control Module
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 118
Mileage: 219486 km
Time Indication: 0
01321 - Control Module for Airbags (J234)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 118
Mileage: 219486 km
Time Indication: 0
01317 - Control Module in Instrument Cluster (J285)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 118
Mileage: 219486 km
Time Indication: 0
Address 09: Cent. Elect. Labels: 6Qx-937-049-C.lbl
Part No: 6Q1 937 049 D
Component: 0000 BN-SG. 1S34
Coding: 25754
Shop #: WSC 13765
VCID: 3C7C17762C66FBFE88B-50AC
3 Faults Found:
01316 - ABS Control Module
49-10 - No Communications - Intermittent
01117 - Generator Terminal DF Load Signal
27-10 - Implausible Signal - Intermittent
01598 - Drive Battery Voltage
07-10 - Signal too Low - Intermittent
I'm thinking it could be the ABS unit? Rather than just a sensor as it couldn't seem to communicate with the ABS unit.
Any brights ideas chaps and chappess'
Battery isn't getting charged.
The alternator load wire is broken. This is the fault that tells you that:
Seach on here for it and there are loads of posts. Very common.
Phil
Must be the time of year for this. Happened to me recently, blue "load" wire had snapped.
Phil
Would that cause the ABS problem?
did you have the same problem as me? Also where is the wire located? Off the alternator?
It could do yes. If the ABS controller isn't getting the right voltage then it can cause it along with all the other controllers in the car to go funny.
It's a good place to start at least as it's an easy fix and very cheap.
Phil
No abs light but it can cause it.
When you turn the key for electrics only, do you get the battery illumination bulb on the dash? Should be red.
If not the wire is snapped.
Thanks for the replies guys! I have checked that Bowen, I'm not getting a battery light on switch on so will check there over the weekend to see what condition the blue wrote is in. Is it fairly obvious when you get underneath it which wire it is?
Those ones: http://www.seatcupra.net/forums/showthread.php?t=209472
J.
Alternator load sensor wire
Just heading to the bookies to put my house on it :)
Bye
Alternator load wire it was!!! Thanks guys :) bit fiddly but extended and done, in fact I bypassed the plug completed as it was broken so close to the plug. The cupra.net guide was handy but it was fairly obvious once underneath the car on the passenger side!
