Fitting a honda S2000 air filter
are you running a standard map?
I am mate, Yes. All stock. Bar the s2000 filter that I put on for a few weeks.
  • Replies 91
  • Views 39.7k
  • Good write up. A very simple and effective mod I too used the valve thingy to locate it into a groove and then its stayed put
  • Matt Gibson
    Matt Gibson
    Eurocarparts have them @ £13.95 at the moment with the promo code SERVICE25 just ordered mine! Cheers for the tutorial Kyle.
  • PoloGTimposter
    PoloGTimposter
    Awesome, well it came in the post today so will be installing that bad boy over the weekend. Interestingly enough the picture on the euro car parts website showed the filter with green paper but it'
just fit a tiny vac filter. Merc have them. called a micro filter. i have 1 on my SE.. will take a pic of the actual thing next time i goto car.
heres a google pic for now...
costs about £1.60 and is perfect fit for vac line.
Oh OK. Didn't know one of those was required tbh. I drilled a hole into the filter and pushed the vac pipe end through that.
I'll look into the mini filter jobby. See if that makes a difference.
Cheers mate.
had 1 on my mapped pd130 bora and same on the se with no probs ;)
Gonna have to try one of them mini filters myself, mine keeps bogging down and spluttering at low revs. But is fine in huger gears. Only started happening when I did the filter change!
As promised yesterday..   heres the wee little filter i use for my vac system...
tucks nicely behind the ecu box
Do you have a part number for this by chance?
part number is...
A000 078 09 56   :)
Mine had an cone filter on and it had no power (like seriously no power had to drive it in boost to pick up speed constantly down gearing it) till 2000rpm then all of a sudden a massive boost!!
I went back to the original box!
Sounded amazing though
What's the best way around this I have a 2002 asz engine
Does anyone have a video of the Honda s2000 air filter sound by any chance ? This looks a great easy , simple modification . Whats the difference with a filter like this then ^ and a ordinary cone filter ? Thanks Justin ...
the only difference is the look of it in your engine bay, and a constant drone when driving slow....
Fitted my Air Filter today and switched from my Pipercross Panel Filter which was very good for a panel , Such an easy modification and easy to fit ( Nice snug fit ) , definetly one of the easiest and cheapest moifications i have done to my fabia vrs , only costing me £12.30 from Euro Car Parts and thats obviously not costing the cold air feed pipe which i will probably order for £10 off ebay instead of my pd150 air intake that i have currently fitted . You have turbo flultter on low revs changing between 1st and 2nd gear which is nice as it echos really well esecially if you have de-cat exhaust , from 2000 RPM onwards the deep drone sound is out of this world and just sounds stunning , doesnt even sound like a diesel , you would think it would be a petrol car if outside listening to it , seems to be pulling slightly better from 2000 rpm revs on aswell . Im very happy with this Modification and would recommend this to anyone wanting to try it out . :rofl:  Thank you Kyle ... :D
I fitted an s2000 filter to my furby vrs yesterday
In terms of sound only flutters with the bonnet up which is annoying!! Also drones when driving normal, my jabba sport cone in a box worked better and much more responsive, I think there best suited to the octy grass!!!
Vrs""
  • 10 months later...
Did this today. Great guide. Thanks.
Yeah I've had mine back on for past few months. Used as daily commuter. No probs at all. Everyone loves the sound it makes when i give it some. Great mod for the price.
Is the maf the same size on the pd100 and pd130? If so I'll be buying the filter :)
  • 6 months later...
Can't seem to find this anywhere, do you have a link to it by any chance?
