Side mirror adjusting knob
Hey guys... need some help here...
My k nob broke off.... can I just replace the k nob or the entire switch?
Any guys know the part number for this and the costs?
Thanks a million!!! :)
5546.attach
Think you will find its the whole switch, mine broke and whole switch was replaced under warranty by dealer - luckily in last month of it running out
John
Whole switch? Hope it won't cost alot :orb_upset
mine went in france ,replaced it back here at
Lightspeed, Hopefully the redesigned part is stronger.
Like your avatar by the way.
Whats that little gadget under your air vent Lightspeed?? I want one :D
Lightspeed' date=' Hopefully the redesigned part is stronger.
Like your avatar by the way.[/quote']
One of the guys in the club just told me that I can get the part for SGD50 at one of our local workshops.... cool ... that would be 16pounds ... whew!!! :)
Avatar? I would love to have that ride... sadly, it's not too affordable this side of the planet :thumbdwn:
Hi! That's a turbo timer by Apexi ;)
  • 4 weeks later...
Follow up to what I previously posted...
I managed to get a switch from a local stockist
Part number 1U2959565L 01C
Problem is, this switch looks different from the one I have previously...
This one has goes like this
R (Top)
Heater (Middle)
L (Bottom)
while the one in my car (the one that broke) is
Heater (Top)
L+R (Middle)
R (Bottom)
I'm pretty sure that the controls would not match the pictures if I fit this new switch in...
Anybody has the correct part number for mine?
6005.attach
6006.attach
Plug it in and it should work just fine, the part has been superceeded many times as mentioned earlier.
It's gonna work alright?
Was afraid that after plugging it in, whenever I want to adjust the right mirror, it's actually turning on the heaters or something... hope you get what I mean :twirl:
The door panel must be removed in order to get at the switch right?
The surround just pops out from behind the handle and you can get the switch out from that. No need to take the door trim off.
The face is different on the switch but the way its wired is exactly the same so dont panic.
for example
for example
Hey! Thanks for the tip! I went down to the car after reading your post and took out the panel and tried the new switch and it works! :thumbup:
Only problem I have now... is trying to get the darn old switch out from the panel... :(
If only the "service advisors" here were even half as helpful as you... thanks alot! :D
I finally got the offending switch out ... now to replace it in the car.... Finally! :D:D:D
6009.attach
