retro fitting columbus and bluetooth to a 2005 : anyone ?
iv retr fitted a columbus to a 2005 octavia.. and fitted bluetooth today.. but my phone cant see it
do i need a new gateway ?
If anyone has done this to a simlar year octavia your inout would be appreciated
also planning this too you will need to upgrade the Can-Bus too, we are in luck with 05's as they should be behind the glovebox though :)
Can-Bus upgrade will stop battery drain i believe.
well, i thought the latest FW fix stopped power drain but mine still doing it
Old gateways don't see the phone module
ah, makes sense now
TY
need to find someone local to code in a new gateway for me then
Look up the VCDS owners map on this forum to find someone nearby.
Only a modified firmware will prevent battery drain. Or a newer gateway .
TY. just messaged a few members with VCDS
await replies
I can do pre-coded gateways
Drop me a PM with prices eddie, will be in the market for one at some point, what do you need? VCDS scan?  been eying up an AR on ebay for an upgrade at some point, along with a comfort module!
