Front Sway bar Link (Metal or Plastic)
Hello guys
I have a 2002 Octavia L&K 1.8T AGU Engine  Chasis No.TMBAL41U928549849
I need to replace the front sway bar links
Can somebody help me with the correct part number I need for my car.
My car has the factory wheels with 205/55/16  tires and I just want a confortable ride. The links I have in the car are the factory plastic ones but I saw on ebay that they have these parts available also in metal too.
I found this part number: 1J0411315 and the only diference is that they have the same part number but ends with the letter C, G J and K.  I think the letters has somenthing to do in the size between the screw holes.
http://www.ecstuning.com/Volkswagen-Jetta_IV--1.8T/Suspension/Sway_Bar/3
Please help me with the correct part for my car.
THX for your help
Isaac
Thats what we call a drop link.  Is it the drop link itself or just the bush you are looking for? By the way. we normally call a sway bar an anti roll bar in the UK- if you search in the forums for Anti Roll Bar or ARB or FARB (Front Anti Roll Bar) you will find the part number you;re looking for I'm sure. I have the VRS version which has a different front end set up to the L&K
I finally order a US$ 17.oo kit that include the rubber bushings inserts for the Drop Links and the rubbers for the Anti Roll Bar.
I hope I made a good decision......... What you guys think?
THX
I personally don't like to depress and repress small bushing like that because they don't have a metal support (outer ring) and they won't be as solid like an factory pressed link.
