How do I Get to hand brake adjuster from inside car
How do you remove the plastic console sitting over the hand brake something is stopping my hand brake fully releasing and discs and pads starting to get hot.
Search for threads on adding the Jumbo Box on this forum as they show you how to remove the centre console.
Thanks just am. Was on my iphone when I first looked so could not find it. What a faff to just do the hand brake.
If you don't have the jumbo box you may be able to remove the rear ashtray and get to the adjusters from there.
Are both dudes getting hot?
If not, it's probably not the adjuster you need to be looking at...
I think it's this rubber gaiter bit stopping the hand brake going low enough. It has a load of creases in and I can't force it down all the way hence no fully released hand brake.
