rear view camera on columbus
perfect TY
where do i order the cable needed as the cameras are all over eBay but no cables compatable
This is where it can get a bit tricky. I went for a boot release camera and Kufatec interface
Not the cheapest option but excellent & well worth it.
Have you found a camera you like?
Here's a link to a camera I located for MikeHolroyd (as near as poss to mine). More expensive than the ones you like but excellent picture quality & work perfectly with the interface kit.
(Drop Mike a PM, I'm sure he'll confirm details)
Edited by ProfesorDeBuceo
ah, if iv fitted the bluetoooth then ill have no room to fit RVC too ??
I have both, they fit well enough.
Sorry to hijack the thread slightly. I have been thinking of doing this to my car. Do I need both the items in this thread for the installation.
http://www.briskoda.net/forums/topic/294749-reverse-camera-fitted/?hl=%2Brear+%2Bcamera
Secondly I never realised the reversing camera wont work if the Columbus firmware is patched for the battery drain issue. I have a new canbus so I dont suffer this issue, however I have the 4020 firmware that is patched for use on Revision A/B units (mine is revsion B) but this also includes the battery drain patch.
http://www.rnsfirmware.com/firmware-4020-for-older-european-rns510-units/
Does anyone know where I can get the 4020 firmware that will work on a Revison B but without the battery drain patch.
^ yes, you will need both those parts
After a lot of frustration, my camera image is now perfect, now that the power is taken from the boot interior light rather than the reverse lights. There's a photo of the image I now get in post 14 of this thread.
By way of a footnote: Mike; I now see they do a suppressor/relay (extra cost) which might have resolved your interference issue in one go. Better late.... & all that...
