My hard day(s) work :)
You can change the fixings!
Just unscrew them anti clockwise you might need some pliers or something for leverage
Yep did the same to mine.
I just used wire cutters on them in front and back then fitted the vrs plastic screws
Looks better with the OEM vrs mats in.
Sent from my XT1032 using Tapatalk
Looks spot on bud
I had the issue round the pedals too. Carpet just wouldn't fit right. I had to trim a little bit off in the end. Iirc the early golfs had throttle cables to the throttle bodies, the vrs was electronic so this probably explains the difference.
