Loss Of Power Fabia Vrs 130
Hi guys am new on the forum, i bought fabia vrs 2005 model black with sunroof & heated seats
132k fsh.Whilst driving Engine light comes on with loss of power, when you turn the car of and re-start it power comes back again.
I have changed maf sensor no joy... had it on the diagnostic which provided 4 codes
17932
17957
19459
19461
Can anyone possibly help
Regards Aly
Unfortunately, it sounds like the usual faulty/clogged VNT.
http://www.briskoda.net/forums/topic/243533-the-mr-muscle-vnt-turbo-treatment-thought-we-needed-a-guide-of-sorts/
In regards to the fault codes, clear the fault codes and scan again to see which codes return.
1.17932/P1524/005412 - Fuel Pump Relay (J17): Open or Short to Ground
Possible Symptoms
Engine still stand
Possible Causes
Wiring from/to Fuel Pump Relay (J17) faulty (Short to Ground)
Possible Solutions
Check/Replace Fuel Pump Relay (J17)
2.17957/P1549/005449 - Boost Pressure Controle Valve (N75): Open Circuit / Short to Ground
Possible Symptoms
Irregular behaviour
Loss of power
Limp mode
Possible Causes
Wiring and/or connections faulty (short circuit)
N75 faulty
Possible Solutions
Check wiring and connections
Check / Replace N75
