Bluetooth OBD Adapter in Superb
Having now found some other topics talking about OBD, people mention the ELM 327.
Would either of these be OK?
http://www.ebay.co.uk/itm/Super-Mini-OBD2-ELM327-V1-5-Bluetooth-Car-Scanner-Android-Torque-Auto-Scan-Tool-/161006648839?ssPageName=ADME:L:OU:GB:3160
http://www.ebay.co.uk/itm/Bluetooth-Android-Torque-Car-V1-5-ELM327-OBD2-OBDII-Diagnostic-Code-Scanner-UK-/321149933981?pt=UK_Diagnostic_Tools_Equipment&hash=item4ac607199d
Still looking for info on where OBD port is in Superb. If it is near the footwell I might go for an adapter that does not stick out too far.
Also I read on another forum about OBD draining battery when plugged in by car off. Is this something I should be concerned about?
Hi,
don't know if it's related but after leaving an OBD Bluetooth adapter in the car my battery went completely flat.
I used this one http://iobd2.co.uk/ to stream data to my iPad
The port should be near the footwell, above the throttle pedal. Go down with a light to find it.
Thanks for reply. I will have to find the port location I think before buying an adapter.
If it is near the throttle then I might want a small OBD Adapter.
Do you knock yours when driving?
No problem it's very well hided and should be the same in the Superb I guess
