Clutch slipping - gearbox leaking ...
Hi guys-
The other day I was punishing the car a bit because I had to go thru some snow ...I took it on the free way and noticed that the clutch slipped in 5th ...
Tested it and yes clutched definately was fu¤%&  .... looked under the car ...and oil/fluid was leaking.... looking in the flywheel inspection hole ...seemed like things looked wet.
Car is a 1999 -  1.6 AKL - box is a DUU which was replaced already once ( so should not be with the infamous rivets )
engine/clutch  was replaced with a brand new one a year ago ...so would like to keep car rolling..for a few more years  ... low on $$$
If car is in idle there is an noise...that vanish when clutch is engaged..
Any one got some suggestions??? the box/engine/transmission have for a while on/off made a clicking sound ..especially when engine braking -  so maby its box is dead...
CHEERS
My guess would be that the oil leak is both your problems!
I mean that the gearbox probably has a main seal leak and this oil has contaminated your clutch pressure plate and causing it to slip as its contaminated with oil.
Sounds to me like you need a recon or second hand box and new clutch plate.
Sorry
Paddy
