o2 sensor
right as ya know i just replaced my coolant temp sensor now im getting code for o2 sensir this the lambda sensor ? can that cause car to run funny too
Aye, lamda is the same as 02 sensor. If it's goosed your engine will run really rich or really lean. Ecu uses the sensor to adjust fuelling
Sent from my GT-I9300 using Tapatalk
one thing after another with this car but i love the car lol so all decent parts
What code are you getting?, sometimes sai system not working will bring up no 1 lambda prob heating intermitent warning, as its supposed to flood engine with air forcing probe/cat to warm up faster.
i cant remember the code i cleared them lol when i get car bk thursday ill have a look
found code 17511 and 16517
I would check the wiring in the connection
The code i was refering to is 17511, 16514, usually means the sensor is fubar, but also refers to wiring to it under the o/s floorpan.
sensors are such a ballache when they go wrong. A new lamda sensor definitely won't do you any harm and you need to check the entire loom for break so long probe voltmeter it is- depends which one you;re more comfortable doing first because it'll be either 1 or the other
Sorry, crossover on posts, with those 2 codes it is probably the sensor, but as Nerd said check the connector first, especially with all this water we have around at the moment.
mines decatted so 1 code i know about
1 can cause the other as a knock on effect ;)
gonna have to get it mapped out i think
