Octy vRS 312mm brake kit
The usual 312mm brake package.  Fully working upgrade kit for Fabia vRS mark 1 (and others running 288mm brakes as normal)
Lots of meat on the pads, and discs look a bit tatty around the edge but car had been sat around a little while.
£150 ono including me shouting courier cost. :)
Where about's are you located?
Given you're in Maidstone, I am almost quite literally the other end of the south coast - by the sea in Devon. near Exeter. : :)
I take it this is ready to bolt straight on to my fabia or would I need to buy new brake lines as well?
Don't quote me, but I am 99% sure you just use your original brake lines with these calipers. :)  Unbolt at caliper, and attach to these calipers once fitted.
And yes, they bolt right on, and also sit under the oem 16" alloys too. :)
Couple of photos of them in better profile and given a little wash
Yah you can use the standard hoses, I did so on my ibiza with 312's.
I am open to reasonable offers.  Brakes most likely coming off on Tuesday, :)
99% sold now, so locking this.
Will only reopen if the smelly brown stuff hits the fan for some odd reason. :)
Don't forget I have a full interior from this Octy too. ;)
Guest
