Boot Leak
I have a had a boot leak for a while that when it rains overnight I end up with approximately 7-8 large drips of water pooled around one of the rear passenger side headrest holes (i haven't got a headrest fitted in this position due to baby seat). It is enough that I have started leaving a jug in the car overnight so that the water doesn't run down into the seat foam.
At first I though it might be the boot seal so tried a new boot seat but nothing changed. Next I tried sealing around one of the metal joins at the top corner thinking that it may be getting through a small gap but again this did not stop the leak.
After removing some of the plastic trim at the top near the roof lining I have now managed to narrow it down to a small hole in the body work when one of the blue trim clip goes.
Now I can't really figure out how the water is getting in and then leaking out of this hole as obviously it hasn't done for the last 5 years.
I have attached two photographs to try and show the exact bit that I mean. Any help would be greatly appreciated.
Do you have a sunroof?
Yes I do mate
Maybe one of the sunroof drains are blocked? And its running threw the roof
Yeah good thinking what the best way to check these and clear them out?
I think the drains maybe at the front of the sunroof ive never looked myself on the vrs. Might just need cleaning out abit
