fabia vrs mk1 clutch price
replacement clutch and dual mass fly wheel. had two quates so far:
£610.00
£780.00
Not sure myself, but I know you can buy the clutch, DMF and Slave cylinder for about £300.
So maybe see how much they would do it for fitted.
Sounds expensive.
The hardware can be got from carparts4less for £305
I got my local VAG specialist to fit for £140.
whats the discount code?
saveme75
It might only work on some accounts.
If it doesn't create an account, add some items to your basket, but don't check out.
In a couple of days, you'll have an email with a voucher code.
recently heard someone mention a figure of around 700 from an independent vag specialist, so not far off
£610.00
£780.00
If thats std parts thats... erm... well alot.
I payed something like 300. Think it was less actually as I got other stuff too and for every 100 you got 15 off so I ordered in a few orders lol.
Mine is still going strong and its done over 10k now unlike the one in my sig :-s
i had a quote for oem parts from TPS @ £500+.
has anyone got the part numbers? as i have heard some vrs's need sach and some another brand?
If you're replacing everything, it doesn't matter what brand you use.
If you're only replacing the clutch you need a sachs clutch to go on sachs flywheel, LUK clutch on a LUK flywheel etc.
got quoted £380 parts only euro car parts....TpS told me i can't but from them because i aint trade and GSF quoted about £398
Use carparts4less instead.
It's the same company as Euro Car Parts, but online only.
Use the code SAVEME75 in your basket.
called car parts for less and they said they need to know if its a sach clutch or luK...???
If you're replacing everything, it doesn't matter what brand was fitted before.
Sachs kit is cheapest on CP4L
The part numbers are on the image above.
thats what i thought..... they seem to think it maybe either and they need to know???
