Calling an FL owner with OEM BT and MFSW installed
I would be very grateful if someone with an FL with OEM BT installed and a MFSW could tell me the options they have for
1. ending a connected call; and
2. rejecting a call;
apart from the MFSW telephone button itself or the head unit.
Are there any options to do either of these either via the maxidot steering wheel scroll button or the stalk please?
This will potentially help me solve a problem with my own pre FL bluetooth and steering controls, so any help gratefully received. Please don't be confused by the FL and pre FL references, it is deliberate and I can explain if necessary!!
Anyone help with this question pls?
Adam
Adam,
There is an option on the maxi dot to end the call plus some other option(s) available by the scroll wheel. When I have a spare 15 minutes I will get a list of the options available.
Thanks for that moldavite, that would be most appreciated.
I can use the ok button (push down the scroll wheel on the right) to answer or end calls
same goes for the phone button
Thanks Ed. Am trying to help the autopolar programmer to emulate end and reject calls on the polar fis link box so he can code the older second pre fl reject/end phone button to do the same. This will help hopefully.
Adam
